Warning: session_start(): Cannot start session when headers already sent in /www/htdocs/w016f8be/das-bemalforum.de/includes/vb5/frontend/controller/page.php on line 71 Sternenstaub - Das-Bemalforum
Sternenstaub
    AW: Sternenstaub
    Wiederfinden ist der Gedanke. Und solange ihr coole Links wollt, lege ich welche nach. Ich habe reichlich, und es werden mehr
    "ARE THOSE BOOTS BULLED?"
    "Yes, Sir!"
    "BULLSHIT!"
    Vorsicht!
    Diesen Link nur mit Sonnenbrille öffnen! Akute Gefahr zeitweiser Erblindung! :mrgreen:
    http://www.track-link.net/forum/research_ww2/20353
    [bulling]: Rumour has it that bulling was introduced to British regiments in India to occupy their spare time, which would otherwise be spent drinking or womanising. Bulling is officially not practised now but the term still exists, being replaced by the words 'polished to a deep shine', but it means exactly the same thing
    So geht es:
    Initially use a hot spoon to burn down the dimples (if a new boot) and build up the layers; this can take ages before it turns out right. If older boots make sure they are really clean before bullying.
    Polish with Kiwi Parade Gloss and plain water, I didn't really use spit; you could get a special bulling cloth from Sylvette which worked wonders...just keep it damp and tight around you fingers. Rub around in small circles alternating the water and polish...as the shine started to build up reduce the amount of polish and make the circles bigger. I used to put a layer of dark tan every now and again it gave the black a deeper colour I thought. Or that could have been the alcohol working.
    Cotton wool and water helped get that final shine; under a running tap in the washroom.
    I didn't use tights to get that final shine..the wife would've killed me.
    Some of the lads used Klear floor polish but if it rained it turned white...a good product was Morello which I think was German.
    Better still; there is always someone who'll do them for a few beer tokens.
    Instructions courtesy to Martyn Smith, UK
    Für den Fall, daß ihr mal Langeweile habt, den Weihnachtsmann gebt oder zu einer Beerdigung geht. Muß ja nicht die eigene sein.
      AW: Sternenstaub
      Langley Models UK
      http://www.langleymodels.co.uk
      We have trucks, lorries, buses, cranes, figures of people and animals, horse drawn vehicles, gardeners, builders, policemen, fireman, mothers with prams to name but a few.
      Also so ziemlich alles, insbesondere auch Tiere in 1/43 = scale "O":
      http://www.langleymodels.co.uk/acata...sories_78.html
      Die kleinen Tiere passen sehr schön zum Heroscale. Insbesondere Vögel und Wildtiere findet man eher selten. Die Gußqualität ist gut. Bin zufriedener Besitzer u. a. von Katzen, Hasen, Igeln, Füchsen, Dachsen, Eichörnchen, Eulen, Reihern, Giraffen und anderem Getier. Bitte nicht von den Artikelbildern abschrecken lassen. Es gibt bekanntlich verschiedene Malstile - Comic, NMM usw. - und das ist, ...äh, Modellbahnstil?
        AW: Sternenstaub
        Mantis Miniatures
        http://www.mantisminiatures.pl/EN/
        Das Pendant zu den kleinen Tieren bietet Mantis mit seiner Reihe von Tieren im Maßstab 1:35. Besitze u. a. die Wildtiere. Es gibt noch asiatische, nordafrikanische und Stadttiere sowie Fische(!). Weitere werden wohl folgen. Diese Tiere sind aus Resin und sehr fein gegossen. Da muß man schon beim Malen aufpassen, daß man denen nicht mal eben die Beine abbricht. Auf der Homepage unter "Accesories" zu finden. In Deutschland bei verschiedenen Modellbauversendern erhältlich.
          AW: Sternenstaub
          Toni Mattelianos Scale Model Index
          http://www.scalemodelindex.com/
          Die Mutter aller Indexseiten. Die älteste Modellbaulinksammlung im Internet. 14 Jahre und weiter wachsend. Momentan über 4.000 Links zu Firmen, Foren, Vorbildseiten, Clubseiten usw. usf. Falls man mal was sucht und andernorts nicht findet
          Edith sagt: Gone by the wind. Leider nicht mehr existent.
          Zuletzt geändert von NogegoN; 10.03.2022, 19:23.
            AW: Sternenstaub
            Archer Fine Transfers
            http://www.archertransfers.com/
            Lee Archer produziert Abreibebilder (das sind dry transfers auf Deutsch) hauptsächlich für den 1/35er Militärmodellbau. Markierungen, Beschriftungen, Flaggen, Uniformabzeichen. Dazu kommen ein paar weitere interessante Produkte:
            Abziehbilder für Augen (Pupillen) von 54 mm bis 1/4. Jeweils 5 Farben, mit Schatten und ohne und mit Irisreflex und ohne. Außerdem für die größeren Maßstäbe eine Serie fotorealistischer Pupillen. Weiterhin gibt es verschiedene Monsterpupillen (mit Rund- oder Schlitziris) und Animeaugen.
            Tattoos (klassisch, keltisch, tribals) ebenfalls in dem Größenbereich.
            Nummern und Buchstaben.
            Eine besondere Spezialität sind plastische Oberflächendetails, die mit Resin auf Abziehbilder gedruckt werden. Nieten, Schweißnähte, Antirutschbeläge, Holzmaserung etc. Funktioniert wie ein klassisches Abziehbild, aber liefert erhabene Details. Sehr praktisch, um z. B. mal schnell ein paar akkurate Nietenreihen anzubringen.
            Funktioniert ganz gut, hat aber 2 kleine Nachteile: Der Trägerfilm haftet nicht gut, so daß etwas Klarlack, Future oder ein Decal-Hilfsmittel hilfreich ist. Darauf wird aber auch in der Anleitung hingewiesen. Der andere Nachteil ist der recht dicke Trägerfilm. Bei größeren Modellen hilft eine gute Grundierung. Noch besser ist es aber, den Film wegzuschmelzen, indem man z. B. Microset und Microsol zur Anwendung bringt.
            Die Qualität der Produkte ist hervorragend. Versand auch. Schnell und preiswert.
            Noch ein Tip zur Homepage: Ihr müßt auf die 3 farbigen Rechtecke mit den Namen der 3 Produktlinien klicken, um in den Onlineshop zu kommen.
            p.s. Lee Archer ist auch Autor der "Panzerwrecks" Serie. http://www.panzerwrecks.com/index.html Die Produkte sind also garantiert gut recherchiert.
            Zuletzt geändert von NogegoN; 13.12.2010, 21:55.
              AW: Sternenstaub
              Der Urzeitshop
              www.urzeitshop.de
              Für Dinosaurierfreunde. Repliken von Fossilien, Skeletten, Schädeln, Klauen, Dinomodelle aller Art und Größe ( komplett fertig oder zum Selbermalen) von 1/72 bis 1:1. Von letzterem sogar ziemlich viele. Also, wer schon immer zu Höherem strebte: Hier gibt es ihn, den T-Rex-Kopf in Originalgröße für das Wohnzimmer. http://www.urzeitshop.de/product_inf...etem-Maul.html
              Wahlweise mit geschlossenem oder offenem Maul. Praktisch, um Pinsel abzulegen oder Wäsche zu trocknen :mrgreen: Ist zwar schon bemalt, aber man kann ja noch etwas altern. 2-3 Pfund Pastellkreide sollten reichen
              Für den Garten noch 2 lebensgroße Raptoren, und ihr werden nie wieder von Vertretern und Missionaren behelligt.
              Zuletzt geändert von NogegoN; 14.12.2010, 12:37.
                AW: Sternenstaub
                Masterpiece Models
                http://www.masterpiecemodels.com/
                Wo wir grad bei Dinoknochen waren. Die haben auch eine kleine Auswahl. Eigentlich wollte ich aber auf deren Modelle der Zeitmaschine (nach dem Film) hinweisen. Dazu gibt es noch die heutzutage anscheinend unvermeidlichen Kampfläufer (falls wer mal was anderes als Dust oder Mig sucht) und eine nette Auswahl an 1/35er und 1/48er Resinbausätzen (Gebäudeteile und Navy-Flußschiffe aus dem Vietnamkrieg) sowie 1/72er Bases. Versteckt sich alles hinter "Models for sale".
                Ansonsten stellt die Firma Repliken für Museen und als Schaustücke für Firmen und Behörden her.
                  AW: Sternenstaub
                  Micro-Mark
                  http://www.micromark.com/
                  Micro-Mark, the small tool specialists from US of A. Werkzeuge gibt es überall, aber die wenigsten Händler bieten alle. Hier findet man alle auf einen Haufen. Werkzeuge für jeden modellbauerischen Zweck. All die Sachen, die ihr vielleicht in meinem Modellbauwerkzeug Tutorial gesehen habt - und noch viel mehr. Den Nibbler. Biegevorrichtungen für Bleche, Drähte und Rohre. Tische mit magnetischen Halterungen zum exakten Kleben von Teilen. Duplikatoren, um nach einem Original weitere Kopien zurechtzuschneiden. Prägevorrichtungen. Sägevorrichtungen mit Führungen und Winkelmessern. Meßzeuge. Chopper. Ätzmaterial. Abziehbilddruckfolien. Bleche und Plastikmaterial jeder Art. Einfach alles.
                  Muß man nicht alles haben, braucht man auch nicht wirklich alles, aber, um mal einen bekannten Werbeslogan zu zitieren: Entdecke die Möglichkeiten!
                  Nachtrag:
                  Bestellung lief tadellos. Das Paket wurde noch am selben Tag(!) abgeschickt. Die Ware war gut verpackt und kam in Bestzustand an.
                  Einziges Problem: Die US-Post hat trotz Airmail über 2 Monate für die Lieferung nach Deutschland gebraucht. Ich glaube, da kam weiland selbst Kolumbus mit seinen Karavellen schneller über den großen Teich geschippert...
                  - N.
                  Zuletzt geändert von NogegoN; 01.04.2011, 20:23.
                    AW: Sternenstaub
                    Eine glänzende Zukunft hat begonnen:
                    The complete Future
                    http://www.swannysmodels.com/TheCompleteFuture.html
                    Future ist eine acrylhaltige Fußbodenversiegelung aus dem Drogeriemarkt, die sich auch im Modellbau hervorragend bewährt hat. Future dient uns als dauerhafter, glasklarer, nicht vergilbender, sich allein glattziehender hochglänzender Klarlack, der die gängigen Modellbaufarben nicht angreift. Klarsichtteile werden damit super durchsichtig und laufen bei Verwendung von Sekundenkleber nicht mehr an (der gefürchtete "Frosteffekt"). Future ist eine optimale Grundlage für glänzende Abziehbilder, deren Trägerfilm dann unsichtbar wird (besonders, wenn man hinterher noch mal Future drüberzieht). Future klebt auch Abziehbilder gut fest. Man kann Future-versiegelte Modelle altern, ohne sich Sorgen von wegen Ablösung der Grundfarbe machen zu müssen. Und, und, und.
                    Wirklich ein "Wundermittel". In Deutschland heißt das entsprechende Produkt übrigens "Erdal Glänzer". Was und wie man damit macht (und wie man es bei Bedarf auch wieder abkriegt) und wie das Produkt in verschiedenen Ländern heißt steht in diesem schönen Beitrag drin.
                    Für eine glänzende Zukunft :mrgreen:
                    - NogegoN
                      AW: Sternenstaub
                      Einfach irre was du alles für zeug kennst!
                        AW: Sternenstaub
                        Naja, ich rede halt mit den Leuten, wo immer ich sie treffe. Auf Ausstellungen, Treffen, Events, Messen, in Shops und Onlineforen. So bekomme ich gleich noch Hintergrundinfos dazu. Und dann bitte ich um ihre Karte oder mache einen Eintrag in meiner Linkliste. Dazu noch regelmäßiges Studium der Periodika im Bahnhofsbuchshop - da sammelt sich dann einiges an im Laufe der Zeit
                        Tja, da sich gerade einige Liebhaberinnen der Großfigur eingeschrieben haben, mache ich da mal weiter. Hobby Link Japan www.hlj.com und e2046 http://www.e2046.com/index.php?language=en aus dem Land der aufgehenden Sonne sind wohl vielen als Bezugsquelle für Mangafiguren bekannt. Mit nicht-Mangafiguren ist es wohl etwas knapper, zumindest bei Resingroßfiguren. Da hätte ich dann gleich einen kleinen Tip vom entgegengesetzten Ende der Welt (also von Japan aus gesehen).
                          AW: Sternenstaub
                          Zotz
                          http://www.zotz-decals.com
                          Eigentlich ist Zotz aus Mexiko (mexikanisch für: Vampir) heutzutage ein Decalhersteller. Die Decals sind super, aber für Figurenmaler sehr uninteressant, weil Flugzeugmodelle betreffend. Früher produzierte Dr. Eli Raphael, der Eigner von Zotz, Resinfiguren. Durch Raubkopien und Abgüsse in Fernost wurde dieses Geschäft aber ruiniert, so daß er jetzt Decals herstellt. Er hat aber immer noch eine Liebe zur Großfigur, malt selber und läßt dann und wann Figuren nach seinen Vorstellungen modellieren, die er als Bausatz mit in seinem Shop anbietet. Die Größe reicht von 1/6 bis 1/2. Hergestellt werden kleine Auflagen. Hier mal ein Link zu einer seiner Figuren samt Bau- und Bemalbericht:
                          http://www.cybermodeler.com/hobby/bu...takeover.shtml
                          Nicht schlecht, würde ich sagen. Doktortitel scheinen übrigens en vogue bei Figurenmalern zu sein, wenn ich da an Dr. Georc denke Dr. Raphael ist übrigens hauptberuflich physikalischer Chemiker, nebenberuflich dann Modellbauer. Wenn man mal Bilder von seiner Vitrine sieht, klappt der Kiefer runter und so schnell nicht wieder rauf :mrgreen:
                          Noch ein Hinweis: Die Bilder auf der Shopseite zeigen komplett gebaute und bemalte Figuren. Verkauft werden aber die ungebauten und unbemalten Resinbausätze. Ich habe mit Dr. Raphael deshalb schon mal konferiert, er wird einen entsprechenden Hinweis noch in seine Seite einarbeiten. Aber noch fehlt er, also bitte dran denken
                          Zuletzt geändert von NogegoN; 23.12.2013, 22:19.
                            AW: Sternenstaub
                            Ooooookay, das waren jetzt alle oder? Haha. Danke dir, da ist einiges bei was ich noch nicht kannte. Aber eine Frage habe ich mal: Hast du das schon ausprobiert im Ausland zu bestellen? Falls "ja" klappte das alles ohne Stress mit dem Zoll?
                              AW: Sternenstaub
                              Alle? Ist ein Scherz, oder? :mrgreen: Ich lauf mich grade warm.
                              Ich siebe aber vorher aus, ob das Thema Miniaturenrelevant ist (vorzugsweise Heroscale), also für euch interessant sein könnte, und checke, ob die Links überhaupt noch funktionieren. Manche Seiten oder Shops verschwinden halt mit der Zeit, wie ModVidArt (miniaturenrelevant)oder AFV Interiors (miniaturenirrelevant, war aber ein echter Verlust) (gut, daß ich da vorher massenweise runtergeladen habe, legal natürlich).
                              Auslandsbestellungen habe ich nicht ausprobiert, ich mach die schon seit Jahren regelmäßig und in alle Welt. Japan, Hongkong, Südkorea, Nordamerika, Neuseeland, Rußland, Ukraine, Frankreich, UK. Allerdings nicht jeden Shop oder Hersteller, den ich hier vorstelle.
                              Prinzipiell sollte man drauf achten, daß die Homepage ordentlich und übersichtlich aufgebaut ist und man in einer Sprache bestellen kann, die man versteht. FAQ, Impressum mit Realadresse und klare Geschäfts- und Versandbedingungen sollten ebenfalls vorhanden sein. Insbesondere sollte VOR Abschluß des Bestellvorganges klar sein, wieviel Versandkosten anfallen. Ansonsten kann man sehr unschöne Überraschungen bei der Endrechnung erleben. Das Problem hat man bei etliche US-Anbietern, die einen gern einfach auf einen Kostenkalkulator der amerikanischen Post verlinken. Die so berechneten Versandkostenangaben können dann mal stimmen, oder eben auch nicht. Ist ein recht teures Lotteriespiel.
                              Außerdem sollte die Seite flüssig funktionieren und nicht mit ewigen Ladezeiten, immer neuen Fenstern oder gar Reklame-Popups daherkommen. Bei als seriös bekannten Anbietern kann man natürlich davon abweichen. Zokai-Murai oder Rainbow10 aus Japan fallen mir da als Beispiele ein. HobbyEasy aus Hongkong auch (ewige Ladezeiten).
                              Wenn man aus Staaten bestellt, die ein etwas anderes Rechtsverständnis als wir hier haben (Rußland, Ukraine usw.) ist es prinzipiell ratsam, KEINE Kreditkartendaten nach dort zu geben. Seriöse Anbieter aus wenig seriösen Gegenden wickeln ihren Zahlungsverkehr über seriöse Unternehmen aus den USA ab. CCnow ist z. B. so ein Finanzdienstleister, der von etlichen osteuropäischen Versandhändlern genutzt wird. Paypal geht auch. Von Western Union Money Transfers würde ich abraten. Die schicken Geld zwar überall hin, notfalls auch nach Afghanistan, aber sie verlangen dafür auch entsprechende Gebühren. Für einen Transfer in die Ukraine z. B. 40% des Betrages. Das grenzt schon an Wegelagerei
                              Ansonsten ist es immer gut, sich bei einem unbekannten Anbietern vorher mal bei anderen Hobbyfreunden nach deren Erfahrungen zu erkundigen. In den Foren tauchen Problemkandidaten ja auch auf. e2046 fiel da z. B. mal mit ihren Geschäftsbedingungen auf. Dito auch inländische Anbieter.
                              Prinzipiell gilt: Wenn man irgendwie ein komisches Gefühl bei der Sache hat, dann besser gleich sein lassen. Das Bauchgefühl ist ein ziemlich gutes Warnsystem. Ansonsten habe ich bislang erst einmal einen Ausfall erlebt, und das war ein englischer Versandhändler, in dessen Lieferung ein Teil fehlte, daß ich nie ersetzt bekam.
                              Fernost hat in der Regel einen hervorragenden Service einschließlich Versandbenachrichtigung. Manche geben sogar Nachricht, daß zum allergrößten Bedauern der Artikel vergriffen sei, aber man auf Wunsch umgehend benachrichtigt werde, wenn nochmal was kommt. Der preisgünstigste Versandmodus (SAL) braucht von dort in Konjunkturzeiten 2-3 Wochen, in der jetzigen Wirtschaftskrise eher 3-4. UPS geht natürlich viel schneller, ist aber teurer und kassiert an der Haustür noch mal eine eigene Extragebühr. Frankreich dauert etwa 10 Tage, oder ewig. UK mit Royal Mail 2-3 Wochen, via Versand etwa eine Woche. USA 1-2 Wochen, händlerabhängig. Polen 7-10 Tage. Ukraine 10-14 Tage. Rußland auch, aber ich erinnere mich auch an Bestellungen, die erst nach einem Jahr ausgeliefert wurden (aber ich habe die vorab bezahlte Ware immer bekommen).
                              Beim Zoll habe ich ein eigenes Zimmer. Na, fast. Bin da öfter im Jahr. Die Zoll- und Postbedingungen findet ihr als (leicht veraltetes) Faksimile hier:
                              http://panzer-modell.de/specials/zoll01.gif
                              http://panzer-modell.de/specials/zoll02.gif
                              Aktuell ist alles bis 22 Euro kostenfrei. Bis 155 Euro Gesamtwert (da zählen übrigens die Versandkosten immer mit dazu) muß man keinen Zoll, aber Einfuhrumsatzsteuer (aka 7% oder 19% Mehrwertsteuer) zahlen. Für teurere Sendungen ist dann noch zusätzlich Zollabgabe fällig, wobei die je nach Warengruppe sehr unterschiedlich ausfällt. Außerdem verwenden Post und Zoll eine eigene Umrechnungstabelle, die vom Tageskurs abweichen kann. Das ist besonders wichtig zu wissen, wenn man unter den Freigrenzen bleiben möchte. Also, nicht zu sehr an die Obergrenze herangehen.
                              Die Post am Grenzpostamt (meistens das für den Flughafen Frankfurt/Main zuständige Amt in Niederaula) tritt leider nicht mehr wie früher bei kleineren Beträgen an Einfuhrumsatzsteuer in Vorleistung. Inzwischen geht alles, was bei der Einfuhr etwas kostet, generell über das Zollamt. Gibt es an oder in der Sendung keine Rechnung oder überschreitet der Wert die 22-Euro-Grenze kommt die Sendung zu eurem Zollamt. Das schickt euch dann eine Karte mit der Aufforderung, binnen einer Woche dort mit Rechnung anzutreten, um die Formalitäten abzuwickeln. Dann darf man dort das Paket öffnen, auspacken, erklären, was was ist und wo es auf der Rechnung steht und dann an der Kassenstelle zahlen, damit man die Sendung mit nach Hause nehmen darf. Nach meinen Erfahrungen dauert das etwa eine Stunde. Wenn der Zöllner natürlich etwas sieht, was er nicht kennt, ein verbotener Gegenstand sein könnte oder wo verfassungswidrige Symbole drauf prangen bleibt der Artikel erst mal da, bis die Rechtslage geklärt ist. Hatte das mal mit Büchern über den 2. WK in Europa, wo der Zoll erstmal Rücksprache mit der Staatsanwaltschaft hielt, die das aber abgenickt hat (und inzwíschen sind meine Zöllner fit in diesen Rechtsfragen ).
                              Sollte man mal nicht da sein oder nicht in einer Woche zum Zoll kommen können, kann man beim Zollamt auch eine Email hinterlassen, daß man die Sendung später abholt oder daß eventuell einlaufende Sendungen bis zum soundsovielten verwahrt werden sollen. Die Emailadresse steht auf der Benachrichtigungskarte immer mit drauf, oder man erfragt sie telefonisch.
                              Ach ja, leider darf man den Zöllnern seinen Dank für die freundliche Beratung und unkomplizierte Abfertigung auch komplizierter Sendungen nur verbal ausdrücken. Sachgeschenke sind nicht erlaubt, nicht mal ein Päckchen Kaffee. Mir hat das Herz geblutet, als mir die Zöllner den Kaffee damals wieder zurückgereicht haben. Man kann ihn nichtmal vor der Tür "vergessen" oder zum Fenster reinwerfen - die müssten den dann nach Hamburg zur Zolldirektion schicken, wo er dann in der Asservatenkammer vergammelt.
                              Alle Fragen geklärt?
                              Zuletzt geändert von NogegoN; 23.12.2013, 22:26.
                                AW: Sternenstaub
                                Als Anregung für neue Werke:
                                "Zappa" von Marijn van Gils
                                http://bp2.blogger.com/_ZYavckOTxoo/...ils+(Open).JPG
                                Kunst kommt von Können, gell?
                                Marijn ist zum Niederknien. Na, manchmal :mrgreen:
                                Das Bild ist von der Seite der Antwerpener Con. Die Figur war auch in Folkestone auf der Euromilitaire zu sehen, aber as Bild ist das Beste, das ich im Netz gefunden habe.
                                Zuletzt geändert von NogegoN; 18.12.2010, 20:00.
