Servus alle miteinander! :D
für die, die mich noch nicht von wo anders kennen. Bin Student, wohn im Wienerbecken und bin CO spieler!
hier meine Version eines Varsÿm Elfen
hoff er gefällt
und wer voten will...http://www.coolminiornot.com/84795...merci
Edite:
Beschreibung:
The base is once again normal 3mm cork, the moss is Piedra pómez from Vallejo!
As for the paintjob; he’s my first mini with both a black and a white primary...which helped me quite a bit to get the high contrast.
I started priming the skin with a 50:50 mix of Basic Skintone #017 and US Tan Earth #134, then shaded the hollows with pure 134. and highlighted back till pure 017 and Flat Flesh #006.
His armour was done just like my previous elves basing it with Light Sea Grey #108, shading it with Azure #062, Ultramarine #055, and a mix of 055 and a tiny bit of Violet #047...highlighting it back up till 108 and then 108 and white.
His pants were based with Luftwaffen Blue #105, shaded with German Grey #167, and highlightet with Pale Grey Blue #153.
His rags were based with Field Blue #058, shaded with Oxford Blue #049 and also highlightet with 153. And in some parts I added thin layers of violet...to make it look kind of “shimmering” but its unfortunately not very visible on the foto!
The top of the blades were based with Sky Grey #154 and shaded with Neutral Grey #160 the underside was based with Basalt and highlightet till 160. On the upperside I highlightet back to 154 and till white.
The colors on the blades are simply very thin layers! The blue ones start with Azure, then a mix Azure and Ultramarine, and the third pure Ultramarine. The green ones are out of Emerald #071, 071 + Park Green Flat #073, 073 + a very small shot of Black Green #100.
And the Gold was done with Dark Yellow #116, shaded till pure Flat Earth #143,,,highlightet back to 116..and white again.
When all parts had color on them. I repainted and ajusted all the highlights on EVERY part of the mini. Meaning I mixed myself the exact colorsmixes, starting from the basecolor till the last highlight color (sometimes also shading colors if necessary). For example to ajust the highlights of the pants I mixed myself one mix pur Luftwaffen Blue;LuftwaffenBlue³+Pale Grey Blue; Luftwaffen Blue²+Pale Grey Blue², Luftwaffen Blue+Pale Grey Blue³; pure Pale Grey Blue. I use normal crown caps to mix my paints in...that way I can dilute the colors heavily!
Hope it helps anyone
Cheers Cheeba
hoff er gefällt
Edite:
Beschreibung:
Cheers Cheeba
